Ignition and Key - car thiks key still in ignition when withdrawn
Old Jun 12, 2007 | 07:24 AM
Myran's Avatar
Default Ignition and Key - car thiks key still in ignition when withdrawn
I have a problem that I am sure others must have had with my 1998 ML320 - when the key is withdrawn from the ignition it used to make a little "click" and this would mean the car knows the key has been withdrawn - but recently the "click" only happens intermittenly (less and less) and when the key is withdrawn the car "beeps" and the doors will not lock with the fob. Is there an easy fix? It seems like the plunger that senses the key is not working or is sticky.
Old Jun 13, 2007 | 02:25 PM
Myran's Avatar
Default RE: Ignition and Key - car thiks key still in ignition when withdrawn
OK - extensive research has now cmade me think that the ignition switch is faulty. Apparently it has a sensor which feels when the key is in the ignition, and it is worn out/getting stuck - so the car thinks the key is still in the ignition in position "0". Hence the beeping when the door opens, and the non-functioning of the remote locking mechanism. Anyone know if the replacement of the ignition switch is easy? I suspect that it is attached to the back of the ignition cylinder and that sounds like a mess to play with - but if anyone knows of an easy way to replace would be helpful.
Old Jan 23, 2012 | 10:22 PM
jnyiszter's Avatar
Unhappy 2002 ml 320
I have the same problem now. When I remove the key from the ignition
it beeps until I close the door. Remote is completely disabled. Does anyone know how to fix this problem..??
Old Jan 30, 2012 | 07:48 AM
panason1c's Avatar
Have you tried squirting wd40, or similar, in the ignition switch?
Old Dec 6, 2018 | 03:17 PM
Camron King's Avatar
Default Ignition won’t reconize key!!
well having a even stranger problem my ignition won’t recognize my key but I was messing around with it the other day and I turned my wind shield wipers on while the key was out and then I put the key back in and it works !! So weird I also noticed that my car isn’t getting enough power from the battery my wipers sometimes won’t even work now but I hear the motor engaging do you think maybe I need to get a new battery and that might solve my key problem ?
dave1973
Feb 4, 2012 08:35 AM
Rajat
Jan 1, 2011 05:03 PM
brantchastain
Nov 3, 2010 05:30 PM
della123
Aug 24, 2008 11:08 PM
marvinp559
Jul 23, 2008 11:17 AM
