Engine Scanner Connection...
Old 03-24-2008, 12:01 PM
philevo's Avatar
Default Engine Scanner Connection...
I have a 1998 ML320 and the check engine light is on. I bought an OBDII engine scanner, where do I connect the scanner to the car? Where is the data access port?
Old 04-02-2008, 09:27 PM
arambayzaee's Avatar
Default RE: Engine Scanner Connection...
Its near the engine release. Grab a flashlight and place your head down where your feet go...then look up, there should be a cover that is hinged and will allow you to insert the code reader.
Old 05-27-2008, 10:05 AM
It's to the left of the steering column on the underside of the dash.
investoreducator
05-07-2009 08:33 PM
boman49
05-09-2007 02:53 PM
pc820
05-24-2006 04:21 PM
investoreducator
03-20-2006 06:39 PM
crit1
11-18-2005 11:16 PM
Quick Reply: Engine Scanner Connection...
