ML350 2003 side mirror bulb change
Old 10-18-2008, 02:17 PM
abusaffaqa's Avatar
Default ML350 2003 side mirror bulb change
Can anyone tell me how to change the light bulb in the right side mirror of 2003 ML350. Bulb is for turn signal. Any help would be greatly appreciated, thanks in advance.
Old 10-18-2008, 04:15 PM
chassis221's Avatar
Default RE: ML350 2003 side mirror bulb change
must replace the whole LED bulb assembly. LED are not replaceable.
Old 10-18-2008, 11:20 PM
abusaffaqa's Avatar
can i do it by my self, and how to do it?
Old 10-19-2008, 09:37 AM
It would be most unusual for the LED's to fail, unless something hit the mirror, I would recommend checking fuses before assuming the LED's are at fault.
You can prise off the interior speaker panel, where the cable enters the mirror, and maybe check for voltage there, or check the earth return.
I hope that makes sense.
Louis Lam
07-23-2009 03:16 PM
norm1412
04-22-2007 05:38 PM
norm1412
04-22-2007 02:58 PM
VQmotoring
05-19-2006 01:04 AM
Dwd123
02-24-2006 10:54 PM
Quick Reply: ML350 2003 side mirror bulb change
