ML350 2003 side mirror bulb change
RE: ML350 2003 side mirror bulb change
It would be most unusual for the LED's to fail, unless something hit the mirror, I would recommend checking fuses before assuming the LED's are at fault.
You can prise off the interior speaker panel, where the cable enters the mirror, and maybe check for voltage there, or check the earth return.
I hope that makes sense.
