trunk won't open on 2003 E500
Old 02-11-2010, 11:13 AM
kriordan1's Avatar
Default trunk won't open on 2003 E500
The remote, door button and trunk latch all are not working . . . but I was able to open the trunk with the key blade. What needs to be done to get all to work again???
Old 02-11-2010, 01:01 PM
chassis221's Avatar
the wires are broken in the trunk where the harness runs down the left side of the trunk lid hinge. you need to remove the left side trunk panel and the cover on the trunk lid assembly/ hinge. your 3rd brake light probably doesnt work and also your tag bulbs too.
Old 03-12-2010, 04:26 AM
UK Texan's Avatar
Isn't there a control unit under the left trim in the trunk? This failed on mine - but during warranty period. :-)
pull the connector to that and re-insert it after 5 mins or so. A long-shot, but it will power it down and also wipe the pins a tad.
Old 03-12-2010, 12:07 PM
chassis221's Avatar
yes there is but on his 2003 E its usually the wires breaking ...repaired tons of them.
Old 03-13-2010, 06:23 PM
NAZ's Avatar
NAZ
NAZ is offline
yes check the wires done loads of this...flipin all day long...
Old 03-18-2010, 09:46 PM
What is the procedure for fixing the wires?
miishmiish
07-26-2022 05:31 PM
dee2000
07-21-2011 07:43 PM
drewspeed150
08-31-2006 07:37 PM
Spp98CLK320
12-10-2005 03:21 PM
Quick Reply: trunk won't open on 2003 E500
