clk 230 over charging
Hi im having a nightmare and could really do with some help. I have a clk 230 komp/cab that is over charging the battery to the point where it has boiled over . I had problems with the alternator not charging the battery. I have changed the alternator and regular for a new one and now its sending too much power through and cooked the battery. Has anyone any ideas on what to do next? Could it just be a bad battery (its only a few months old) or the new alternator is a bad one or could it be that it just needs plugging in and resetting the system?
However much the alternator (or actually the Voltage regulator) floats above ground, that voltage can be added to the output.
It is not a real common problem, but so easy to check it is usually worth it when having weird charging problems.
jspskompressor
11-25-2010 10:49 AM
digieditny
08-29-2010 04:59 PM
MidnightBlueNeon
9
06-26-2006 01:09 AM
