2006 C230 stuck in 1st gear? IDK, help
Old 09-12-2014, 08:54 PM
Beau Bradshaw's Avatar
Default 2006 C230 stuck in 1st gear? IDK, help
Hey guys, I just recently purchased a pre-owned 2006 C230. I was going down a poorly lit street and hit a pot hole relatively hard. Not soon after that (10 minutes) I noticed the vehicle was giving me problems. At first, the car felt like it didn't have the same pick up as it had previously had pushed the gas. Then it seemed like it was stuck in one gear. I would speed up and the RPMs would jump but then would just KEEP going up without ever going back down as when the car switches gears. I then noticed the indicated that lets me know if I'm in park, drive, etc…looked funky as well. It did not indicate what i was in. it had PRND_ _ on the screen and where as the rectangle is usually around the letter of what function your car is in (park, reverse, etc,) my rectangle is on the far right on an empty spot. Any ideas of what the issue may be?
Old 09-16-2014, 02:25 AM
Chubber's Avatar
I would get the car up on ramps or jack stands and give the bottom a quick inspection for dents, debris or loose wiring plugs or frayed harnesses. It sounds like the shift indicator plug might be loose, but I've never heard of that from a bump.
I'm amazed it's driving at all if it's not picking up the shift position indicator.
GMFuzy
01-11-2015 03:21 PM
w168
Mercedes A Class
03-26-2012 09:43 AM
redbjjjj
02-26-2010 12:18 PM
Mixxed
11-25-2006 01:55 AM
Warren C
07-25-2006 09:15 PM
Quick Reply: 2006 C230 stuck in 1st gear? IDK, help
