A210 auto stuck in 1st gear ESP & engine warning lights
Old Aug 10, 2008 | 04:07 PM
w168's Avatar
Default A210 auto stuck in 1st gear ESP & engine warning lights
has anyone had this problem ....
A-class w168 52 reg A210 auto
stuck in 1st gear will not change up ESP & engine management warning lights on plus gear indicator gone off loud clunk when put it drive or reverse ,
Old Oct 29, 2008 | 01:20 PM
jrhilton's Avatar
Default RE: A210 auto stuck in 1st gear ESP & engine warning lights
ORIGINAL: w168
This reply is probably too late, but sounds like the engine and garbox are in limp home mode....don't drive the car, get someone to look at it asap. You dont want to be in the car, and it stop in the road etc, and someone career into the back of you or you damage the engine!
Old Apr 12, 2010 | 06:05 PM
SANJ's Avatar
Hi there,
I too have the same problem with identical symptoms. I was driving my 2003 A210 two days ago, everything seemed normal till I stopped in traffic. The car refused to change up gear with the engine management and EPS/BAS lights staying on. The display showing current gear selection on the instrument panel also vanished. Did you manage to solve the problem? How did you you go about it. I would greatly appreciate any help with is matter ....thanks
Old Mar 26, 2012 | 09:43 AM
sam1972's Avatar
Default A210 stuck 1st gear with no gear indicator
I too have suffered the limp mode with W168 (2003 model).
I've had ECU testing try to rectify without luck!.
anyone has any info on how to resolve this pb ?
tks
Beau Bradshaw
Sep 16, 2014 02:25 AM
redbjjjj
Feb 26, 2010 12:18 PM
ricco7777
Aug 17, 2008 09:50 PM
slick1
Jul 30, 2007 07:05 PM
ebenz230
May 3, 2004 11:29 AM
