2005 C230 how to replace air filter!
Old 06-02-2008, 09:44 PM
SC100's Avatar
Default 2005 C230 how to replace air filter!
i need some instructions and photos on how to replace air filter!
can you help out a Benz Guy?
S.C.
also can anyone please tell me the difference between a w203 chasis and a C230?
[IMG]local://upfiles/32908/374A62B799A841D2A26C6CB9D2B6E9EE.jpg[/IMG]
Old 06-02-2008, 09:47 PM
C280 SPORT's Avatar
Default RE: 2005 C230 how to replace air filter!
A W203 is the chassis and C230 is a model on the W203 and W202 Chassis
Old 06-02-2008, 09:54 PM
SC100's Avatar
What is the diff between the two W203 and W202 chassis?
Scott
Old 06-02-2008, 10:43 PM
C280 SPORT's Avatar
OH. The W202 Chassis is the first generation C Class produced from 1994-2000. The W203 is the secondgeneration produced from 2001-2007
Old 06-03-2008, 10:00 AM
mrcoyote's Avatar
I can tell you how to replace the air filter without any photos. It's very easy. Pop the hood and look at the engine. To the driver's side of the engine, at the front,you will see the cover (black plastic type material) for the air filter. It has TORX HEAD screws holding it down. Remove these screws and lift up the cover and you will see it. Lift UP and OUT from the front. Notice how the "tab" on the filter fits down in the housing and holds it in place, so when you put the new one back in, it's the same way. Simple. Take the time to vacuum out the housing where the filter sits while you're in there. There may be all kinds of junk in there. Put the cover back on and don't over tighten the screws. Snug is fine.
Old 06-03-2008, 12:51 PM
SC100's Avatar
thank you i do very much appreciateyour help!!!
Old 06-03-2008, 05:32 PM
C280 SPORT's Avatar
Are you looking to upgrade the air filter? If so, K and N Air Filters are good. http://www.knfilters.com/
Old 06-05-2008, 12:47 AM
Hi, yeah the air filter isn't that tough but one thing to be careful with is those darn black snap tabs. Mine broke off and my tech said this happens alot..be careful.
Bipper
2004.5 C230K Sport Coupe "sort of"
PelicanParts.com
06-25-2013 11:48 AM
StickyBenz
02-01-2012 06:24 PM
parasuco
03-13-2009 02:21 PM
rbj610
08-02-2006 06:03 PM
anguyen_tracy
09-26-2005 04:56 PM
Quick Reply: 2005 C230 how to replace air filter!
