Code P0600 and P0705
Old 07-17-2007, 01:57 PM
shep47130's Avatar
Default Code P0600 and P0705
We have these error codes on our 2001 CLK 430 (about 72000 miles) and now they are saying we need to replace the transmission modulator, at 750 just for the part, does this sound Kosher?
Old 07-17-2007, 02:39 PM
SunGuy62's Avatar
Default RE: Code P0600 and P0705
In the data I have, P0600 indicates a CAN (controller network communications) error;
CAN Serial Communication Link Malfunction to ESP-
P0705 indicates
Transmission Range Sensor Circuit Malfunction (PRNDL Input)
I don't have the in-depth skill to look at these two codes and conclude that the modulator is the root cause. What I do have based on these OBD definitions is enough suspicion to get a 2nd opinion.
Bob
Old 07-18-2007, 12:02 AM
snanceki's Avatar
The Transmission Selector Module cannot be seen by the network.
Did they give you a diagnostics print out. Does this fit with your symptoms?
This COULD be a connection (corrosion, pin backed out, become disconnected) or module (transmission computer) problem.
However, the most common cause of your problem is a spilled drink in the vicinity of the PRNDL selector which has shorted the module.
Stuart.
ftby59
08-21-2020 12:24 PM
mpalic
01-12-2016 04:14 PM
grkace
02-02-2010 09:00 AM
Silvere430
01-27-2006 03:46 AM
Quick Reply: Code P0600 and P0705
