Both rear cigarette lighter no power
Old Feb 24, 2006 | 09:59 AM
dhs9's Avatar
Default Both rear cigarette lighter no power
I have a 2000 S500 and when I pushed down both rear lighters they did not pop back up with the engine on. I then pryed them out took a multimeter and found good ground but no 12v on either. THe strange thing is the fuses one for each lighter are good and hte other things on the same circuit work. Any suggestions as to why the lighters are inop. They are on totally seperate fuses.
Old Feb 24, 2006 | 11:45 AM
sleepwalker's Avatar
Default RE: Both rear cigarette lighter no power
power supply goes directly to the door control module.
both of them cannot be defective at the same time on the same reason.
i see many defective heating element (the one that you pop-in and pops out when hot). try it on the front ashtray and vice versa if it works.
akum4r
Aug 8, 2010 05:30 PM
brockway
Dec 13, 2006 12:46 PM
brockway
Dec 13, 2006 12:44 PM
bmartin29
Jul 13, 2006 01:46 AM
albfamily
May 6, 2005 06:00 PM
