"oil hi" before AND after oil change?
Old 05-28-2007, 03:51 PM
gsfent's Avatar
Default "oil hi" before AND after oil change?
Recently got oil hi indicator on my '02 ML500. Book says too much oil. Dipstick is halfway between full and add mark. Change oil and filter with fresh. Still getting oil hi. Seems to occur the first time when the water temp gets to about full operating temp (just before opening of tstat?) . No relation to engine speed or load. Will do it 2 or 3 times during a trip. Verified oil level is OK (warm engine, shut down, wait about 1-2 minutes and check stick).
Faulty/sticking sensor?? What else to look for?
Regards,
Jerry
Old 05-28-2007, 05:55 PM
chassis221's Avatar
Default RE: "oil hi" before AND after oil change?
yes pretty common, oil level sensor fault most likely.
Old 05-31-2007, 08:34 PM
gsfent's Avatar
Thanks. Any idea where to look for the sensor? DIY to change out?
Regards,
Jerry
Old 05-31-2007, 11:05 PM
chassis221's Avatar
yes you can do it yourself. you will need a new o-ring for the sensor and there is no oil pan gasket so you will need sealant to seal the pan.the sensor is right above the lower oil pan on the right side,... sort ofbehind the alternator.
Old 05-31-2007, 11:11 PM
the new sensor will come with a new o-ring, you'll need torx socket to r/r the lower oil pan
Old 06-01-2007, 07:16 PM
gsfent's Avatar
Thanks guys, exactly the info I was looking for!
Regards,
Jerry
Laura75
10-30-2010 01:26 PM
81 300 CD
04-01-2006 11:51 PM
buckeye560
04-30-2005 03:44 AM
trey682
04-03-2005 03:28 AM
Quick Reply: "oil hi" before AND after oil change?
