Exterior Talk about your rims, body kits, lighting effects and other exterior mods here.
Install HID in 2003 ML 350. Is this even possible?
Old 09-20-2005, 12:30 AM
MYML350's Avatar
Default Install HID in 2003 ML 350. Is this even possible?
Hi all and thanks for reading my post. I just purchased a 2003 ML 350 and it did not come with HID headlamps. My question is, is it even possible to purchase aftermarket H7 HID bulbs/ballast and install it on my ML? Any suggestions on how to complete this install would be greatly appreciated. Also, where to get them would be cool too. My only concern is that the HID bulb would be too long for the Projector inside the headlight housing.....any recommendations are really appreciated!
Rich
Old 09-20-2005, 11:21 PM
Default RE: Install HID in 2003 ML 350. Is this even possible?
You might need a new reinforcement bracket. HID'S are bigger lights then the standard light. Also make sure the harness is the same.
Old 09-29-2005, 08:01 PM
Its easy to install an aftermarket HID on your ML get a h7 rebase hid and follow
installation procedure.....
Old 04-10-2006, 12:37 AM
raymond~'s Avatar
one of the worst things you can do is to install an HID bulb inside an H7 reflector. as easy as these conversions sound, the resulting beam is fraught with stray light and requires more information than to simply suggest this to be viable alternative. HID D2S bulbs are designed to be used with PROJECTOR headlights. HID D2Rs are designed to be used with HID reflector headlights. find others who have done same conversion, using the same kit, and ask for photos of the beam against wall to determine degree of glare or precision of focus. go cheap and you'll end up blinding other folks...not to mention poor light output.
spierce
08-28-2009 08:28 AM
SkipperZipp
02-24-2009 05:15 AM
gixxer
03-15-2008 12:48 AM
lamdanh
08-11-2006 02:24 PM
borist
02-02-2004 12:11 PM
Quick Reply: Install HID in 2003 ML 350. Is this even possible?
