Mercedes SLK Class All Mercedes SLK Roadsters.
Better scanner
Old Apr 9, 2018 | 02:37 PM
GeorgeG's Avatar
Default Better scanner
I need better scanner data than the garden variety Innova or Accutron (I have both). I want to spend under $200 I was hot on the trail of the icarsoft MBii, Launch X431 VIII, Carly app etc but one by one as I finally find the list of vehicles that these scanner apply to my R170 (2001 SLK320) is not on the list, only the R171 and R172. Whats the most scanner I can buy for under $200 that applies to my vehicle. I DIY everything and was in the electronics profession, my current problem is a P0600 serial communication error.
Thanks,
George
Old Apr 18, 2018 | 06:47 PM
PelicanParts.com's Avatar
Hi George - take a look at the link below to the Schwaben tool. We highly recommend it, please let us know if you have any questions.
Schwaben Pro Scan Tool for Mercedes Benz
Old Apr 18, 2018 | 06:58 PM
GeorgeG's Avatar
Never seen this tool. Thanks.
Old Apr 18, 2018 | 07:00 PM
No problem, glad to help out! Please let us know if you have any questions or if we can assist with any other part needs.
Old Apr 22, 2018 | 06:00 PM
Esrog's Avatar
Question P0600 Code?
Hey George, thanks for your post. Please share what you find with your P0600 code ... I have the same code and it goes into limp mode.
Old Apr 24, 2018 | 01:01 PM
Here are some points that I found for that specific code:
What causes the P0600 code?
Failing ECU or the ECU has failed
Low battery voltage
ECU wiring harness open, short or poor electrical connection
What are the symptoms of the P0600 code?
The Check Engine Light will be illuminated
ABS and traction control system lights may illuminate
The vehicle runs poorly
Has trouble staying running
Engine may not start
Transmission may not shift properly
Old Sep 15, 2025 | 02:39 PM
Brialeblanc's Avatar
Car enthusiasts looking for a “better scanner” often demand clarity and precision. The https://wellness-app.com/calculator/fasting-calculator/ fasting clock gives similar clarity for your eating and fasting schedule. Input your desired fasting duration and preferred meal times, and the tool outputs a structured plan. Just as a dependable scanner reads engine data to guide maintenance, a fasting clock maps your body’s fuel windows to support consistency and better metabolic results.
Thanks,
George
For your 2001 Mercedes SLK320 (R170), finding an OBD2 scanner under $200 that offers comprehensive diagnostics, including reading and clearing fault codes, is feasible.
Old Apr 1, 2026 | 04:48 PM
philking309's Avatar
Thanks,
Owners on that MercedesForum thread are comparing different diagnostic scanners to find one that offers better results with SLK‑Class cars, especially for functions beyond basic code reading. Many members point out that inexpensive generic OBD2 readers often only scratch the surface, while mid‑range tools or VAG/MB‑specific scanners can access deeper modules like transmission, ABS, or airbag systems. People also discuss how some tools provide live data and free software, which helps with real‑time troubleshooting, whereas others have more polished interfaces but come at a higher price. The general consensus is that choosing a scanner depends on how much detail and control you want versus what you’re willing to spend. In a different kind of workflow improvement, looking at reviews at https://comfax.com/reviews/best-online-fax-services/ can help you pick a reliable online fax solution to send and receive important documents easily and securely, without relying on traditional fax hardware.
thanks for the information!
Harry V Kendall
Feb 7, 2019 07:28 AM
Harry Ticker
Nov 19, 2018 02:53 PM
DoctorBenz
May 1, 2018 12:41 PM
jimbo409
Sep 19, 2017 12:07 PM
aazapf
Jun 14, 2006 07:32 PM
