glow plug ?
Old Jun 3, 2026 | 10:47 PM
noswendel's Avatar
Default glow plug ?
I'm replacing the glow plugs in my 84 300sd. The old ones came out easily but I can't get the new ones to start threading. I applied anti seize lubricant but the threads just won't start. I assume it's because of carbon deposits. I've seen some high prices for reamers and wonder if you could use the correct size tap to clean the bore. If that is a good idea, does anyone know what the proper size tap would be? The plug is 10mm in diameter on the part that screws into the engine. Thanks for your advice.
ifthecar
Feb 3, 2013 09:19 PM
keredchang
Dec 22, 2010 07:23 AM
1980300d
Jul 20, 2010 09:35 PM
thirstyvalves
May 29, 2010 11:26 AM
1fastredsc
Dec 3, 2007 08:48 AM
