Wheels/Tires Need custom rims? Have a tire question? Come in and let's talk.
Wheel spacers?
Old Jul 21, 2021 | 04:02 AM
Aries-BONOSS's Avatar
Default Wheel spacers?
I see BONOSS wheel spacers have many new features, such as knurling, disassembly grooves, active cooling grooves.
Is there any quality difference between H&R wheel spacers and BONOSS forged active cooling wheel spacers?
Old Jun 27, 2022 | 09:39 AM
DFergusonMB's Avatar
Almost 12 months later, hopefully I'm not wasting my time here.
Couldn't find very much on the manufacturing process for these two different brands but from what I understand they both use different materials and different processes to construct their products.
From the little info I could find, BONOSS forges their spacers which tends to have stronger construction and durability. H&R boasts lightweight material and anodized finish. Both brands claim perfect fit. Really is up to you. If I had to flip a coin I'd go with BONOSS.
Old Jun 19, 2025 | 11:46 PM
vapofi's Avatar
Both H&R and BONOSS offer high-quality forged aluminum wheel spacers, but there are some differences in features. H&R spacers are well-known for precision engineering and long-term reliability, especially in motorsports and OEM applications. BONOSS forged active cooling spacers include additional features like knurling for better grip during installation, disassembly grooves for easier removal, and cooling grooves designed to reduce heat buildup around the hub. When pairing these spacers with custom wheels, it's important to ensure proper hub fitment and clearance. In terms of core strength and safety, both are solid options, but BONOSS adds some practical enhancements that may be useful, especially in high-load or performance setups.
Old Jul 24, 2025 | 12:02 AM
inam67's Avatar
If your tires sink in sand, stop immediately to avoid digging deeper. Lower tire pressure to 15–20 psi for better traction. Clear sand from around the tires and under the vehicle. Use recovery boards or solid objects (wood, mats) under tires to gain grip. Rock the car gently in drive/reverse to build momentum. Dig ramps in front of the wheels if needed. Redistribute weight over the drive wheels. Use a jack to lift tires and fill holes underneath. If poorly stuck, use a ****** strap with another vehicle (never use chains). After recovery, reinflate tires and inspect for damage. Always be prepared with recovery gear and practice beforehand.
Aries-BONOSS
Mar 24, 2021 09:57 PM
Aries-BONOSS
Mar 23, 2021 10:56 PM
mlg
Apr 15, 2008 10:43 PM
Gary Baxter
Mar 16, 2007 07:13 PM
