Wheels/Tires Need custom rims? Have a tire question? Come in and let's talk.
New wheels fit on older mercedes?
Old Aug 21, 2007 | 02:02 PM
lifethrasher's Avatar
Default New wheels fit on older mercedes?
would recent wheels, like wheels off new 2000+ models fit on my 420SEL? (W126)
Old Sep 12, 2007 | 09:11 PM
father1014's Avatar
Default RE: New wheels fit on older mercedes?
They most definately will, You just need to make sure you have the appropriate spacers. what you have to be care ful about is the rear suspension sitting low when you put the car in gear. I just put a set of Staggered 19 inch cl 65 rims on my 380sec, and they replaced a set of 18 inch hp evo's. 3 inch deep dish lip on both rims, so you should be able to fit new stuff on just fine, just get the spacers
Old Oct 1, 2007 | 10:21 PM
MrFJJ01's Avatar
where can you purchase the spacers? someone I know is selling rims for a 92 600SEL with a 44mm offset. I want to put them on my 86 420SEL which has a 25mm offset. how do you know the amount of spacers that are needed?
Old Oct 15, 2007 | 05:04 AM
merc_lover_w126's Avatar
hey guys; sorry to interupt, but do either of you know if myw126 300se would fit a set of 17"s with an offset of et35. would this fit without any trouble?
Old Dec 6, 2007 | 12:31 PM
Sprint97's Avatar
They will fit. I would try the wheels on for clearence between the brake caliper & wheel & also suspension parts & the wheel. If they are Mercedes wheels, the lug bolts should work (taper inside the flange that the bolt tightens against). If they are not Mercedes wheels, you should have bolts from the same company that produces the wheels so you have the proper taper where the bolts seats in the wheel.
You should measure the protruding length of the threads with the bolt in place as if it was bolted on the car. Measure the original wheels & bolts then measure the new wheels & bolts. They shoul be close to the same length.
My car (2002 S series) has 22 mm thread showing. Any more than 24 mm likely will not clear the brake cylinders. Check the clearence while the car is still on a hoist or jack.
Old Dec 6, 2007 | 12:39 PM
Sprint97's Avatar
MrFJJ01;
You can purchase wheel spacers at www.prestigewheel.com or have the custom made at www.wheeladapter.com
dieselmech174
Oct 21, 2013 04:01 AM
qq007
Jul 1, 2013 06:55 PM
Ngarover
Oct 28, 2011 12:26 PM
silver fox
Jan 21, 2009 08:08 AM
fritzibea
May 18, 2007 09:41 AM
