190E wheels size help?
RE: 190E wheels size help?
ORIGINAL: AMGMercedes
Let's put it this way, my 18 inch rims have rear tires that are 9.5'sand the front tires are 8.5's. Is that big enough?
ON a 190E you need to be careful of wheel & tire sizes, in 17" you need a 7.5 or 8.0 width max. with a minimum of a 35mm offset. 38-40 is better. Tire size should be 215/45-17, some guys run 245/40-17 in the rear, but most times it rubs and you need to modify the fenders. Another way to go is 215/40-17 front and 245/35-17 rear. these are very hard to find, and very easy to damage due to the low profile.
In 18" you will need the same width and offsets, but your tire size needs to be 225/35-18.
If you are in the N.Y. area,call Parts & Polish @ 516-466-3553 ask for Jonathan, tell him Dennis sent you!
Good Luck!
Good Luck!
190e 2.6 rim problem
Good Luck!
Good Luck!
hey how you doing I just bought some rims for my 190e that were from a SL merc that are the same size and I think same bolt pattern but when I tried to put the lug nuts in they wouldn't fit I was wondering if I need spacer or just need new rims altogether
Any ideas
If anyone has any questions on wheel fitment and/or spacing, take a look at the link below. It's a very helpful, easy to understand guide.
Wheel Fitment and Spacing Guide - Pelican Parts
-Dmitry
-Dmitry
