ARMA SPEED ::Winning A Free Arma Variable Airintake
Wanna missing a chance to win Arma Variable Airintake? NO WAY!!!
Just Go to www.armaspeed.com to check and have a great opportunity
to experience Arma Variable Airintake.
My thoughts exactly!!!!!
Why would I want to sacrifice filtering quality 100% of the time for additional power 1% of the time?
High filtering efficiency is FAR more important than high airflow. And, if you have a turbo or supercharger the slight air restriction of a good filter makes no difference to power.
ISO 5011 Duramax Air Filter Test Report
Just want to share some experience to you.
Have you modified any high airflow filter? if yes, do you think it is a little bit lag at lower rpm? Our variable filter just reduce airflow hopefully power output could very close to stock. It means design to minimize low end torque loss. This is our concept for variable filter.
Thanks for your comment and opinion.
This is our dyno test for GOLF 6
It is very clear to see increasing 7%.
I think it should be proved something.
Please do not misunderstand the valve only close at lower RPM and open at high speed RPM so it is still have high airflow.
armaspeed
06-17-2014 04:26 AM
armaspeed
04-23-2014 12:47 AM
