Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
‘CEL' Got You Down? It May Be a Faulty MAF Sensor - By Pelican Parts
Old Aug 30, 2013 | 12:04 PM
PelicanParts.com's Avatar
Sponsor
Default ‘CEL' Got You Down? It May Be a Faulty MAF Sensor - By Pelican Parts
The mass air flow sensor (MAF) is located inside the engine compartment and is used to measure the amount and temperature of air that is entering the engine at any one time. Older style meters used on fuel injection systems in the 1980s measured air volumetric flow, which worked fine but then you also needed a separate sensor to figure out how cold or dense the air was. The mass air flow sensor senses the total amount of air passing the sensor and allows the fuel injection system to adjust the fuel mixture to compensate for cold weather and/or high altitude conditions. The MAF also incorporates an internal intake air temperature sensor which measures the temperature of the intake air.
The first indicator that you might have a problem with the MAF is the presence of a check engine light (CEL) on your dashboard. The check engine lamp can be caused by a wide variety of problems with the engine: you need to read the codes from the computer to get a starting clue as to what the problem is. However, the engine will not be operating at peak efficiency, and you will most likely experience a loss in power and a decrease in gas mileage as a result.
We offer Air Mass Sensors/Mass Airflow Sensors from brands such as Genuine Mercedes-Benz, TPI & Bosch. Shop for MAF Sensors here!
Questions? Let us know!
PelicanParts.com
Oct 1, 2013 12:09 PM
PelicanParts.com
Jul 18, 2013 11:44 AM
PelicanParts.com
Jun 24, 2013 06:18 PM
PelicanParts.com
Apr 25, 2013 11:24 AM
