Ride of the Month This section is specifically for issues pertaining to CBR of the month nominations and voting!
06 C230 sport
Old Jan 4, 2021 | 08:42 PM
C-Benz-Class's Avatar
Default 06 C230 sport
Has anyone run into issues with code P0415? Any suggestions or help is appreciated. This is my first benz. Trying to get it to pass smog.
Old Sep 28, 2022 | 10:40 AM
DFergusonMB's Avatar
P0415, I believe that is the Secondary Air Injection System Switching Valve Circuit Malfunction, or Air Vacuum Control Solenoid Circuit Malfunction. Could be the Air Pump is inoperative, or the bypass solenoid has a bad connection or itself is bad. If you're a DIY guy then try this video.
If you're not a DIY Guy, bring it in to your dealer or specialty shop and let them know your engine light is on and need an inspection. My dealership has a labor rate of $175/hour, you can use that as a baseline for whatever dealership you use. Good luck
Snokng
Jan 8, 2008 11:10 AM
lucky strike
Sep 22, 2007 10:14 PM
sircharles
May 4, 2007 05:50 PM
daveNY
Dec 3, 2006 01:49 PM
ThaChief
May 21, 2006 02:41 AM
