overheating
hi every one
ihave 300e 1989 w124 eng 103 starts to over heating it went up to the midle between the line above the 80 c and the 120c and the hi fan kick in i don,t know what the problem i just boutgh the car ,the air conditioner also is not working , is any relation between the ac not working and the tempreature hi it looks ok when i drive on the freeway but when i drive on the street stop and go it will overheating any help will be appreciated.
A/C WON'T WORK ONLY WHEN IT'S OVER HEATING OR DOESN'T WORK ALL THE TIME?
some cause are:
clogged radiator
sticky thermostat
defective fan clutch (your car use mechanical or electric cooling fan?)
leaky cylinder head gasket
etc.
some cause are:
clogged radiator
sticky thermostat
etc.
hi
it has only 13000 mil since the radiator been changed with the water pump ,tensioner pully and all hoses. the car run fine on the freeways as soon as you get to the city it starts to get hot above the 100c specialy when i turn the car off and turn it on the needle showes almost at the 120c and then when istart drive it it goes down to 100c and stays.. i checked the fan clutch when the car is cool and it seem like it has some resistance.any i do not want to just changing un neceseary parts.
have you tried emptying the radiator as you may have some air, this can cause overheating.
flush out the radiator with a hose pipe then fill in the normal way, see if this helps. If you do find your car overheats, open all the airducts on the car, switch the fan on full until you can get to your destination. This helps keep the engine cooler.
MASSINC
Oct 14, 2004 01:46 PM
