Other Post discussion on all other models not listed above here.
190E door lock inop
Old Feb 15, 2005 | 04:13 PM
mig1f16's Avatar
Default 190E door lock inop
1993 190E. The driver's side door lock is inop. The key will insert and turn in the lock, but the button will not pop up and the door won't unlock (thus all other doors won't unlock). The key and unlock mechanism works fine when used at the trunk. Any thoughts or suggestions? Thanks a ton in advance!
Old Feb 15, 2005 | 11:27 PM
sleepwalker's Avatar
Default RE: 190E door lock inop
was there any pressure difference on feeling while unlocking the other door?
could be the catch?, linkage?, switch?, barrel?
Old Feb 16, 2005 | 11:07 AM
mig1f16's Avatar
hi sleepwalker,
prior to the problem, the key would turn with usual resistance to lift the driver's side door lock (with the others to immediately follow), with the resistance gradually shifting from continuous to resistance experienced just towards to the end of the rotation just prior to complete failure. Now the key just turns clockwise/counterclockwise with no resistance and no lock movement.
billy
S_benz
Nov 27, 2017 05:22 PM
SirKnightE
Apr 12, 2011 09:06 PM
BobbyK
Nov 23, 2005 10:30 PM
legenesepimp
Nov 2, 2005 05:04 PM
hoytheld
Oct 30, 2005 02:56 PM
