Cooling Systems During Dyno Runs
Hey everyone! I’ve been doing a few dyno sessions lately, and heat buildup is becoming a problem. My cooling fans don’t seem to keep temps under control during long pulls. How do you handle cooling when running multiple tests back-to-back without risking engine heat soak?
That’s a really common issue during dyno runs. Airflow inside a test cell can never match what happens on the open road, so heat builds fast. What helps is synchronizing fan direction, coolant circulation, and oil temperature monitoring. When it comes to maintaining consistent conditions for analyzing your car’s performance, the modules Dynotest https://dynotestpro.com/ make it easier by stabilizing environmental parameters and tracking temperature data across runs. With that kind of control, you can focus on tuning accuracy instead of worrying about heat skewing your results.
jikian
Sep 11, 2019 07:59 PM
PelicanParts.com
Sep 20, 2013 06:55 PM
