Door lock problem
Door lock problem
I have a 2003 CLk 500 with 64,000 miles on it .
Upon unlocking the vehicle to enter it as i normally do by pressing the unlock and pulling the handle .
The Electric mechanism that locks and unlocks the door is rapidly opening and closing in a 3 to 5 sec span . Sounds like a machine gun while the "pop" manual goes in and out .
Its only acting up on the Drivers side .
Has anyone had this isssue ? is it a glitch in the wiring or programming ?
Can the Unit be replaces without Computer programming and or synchronization .
My fear is that its probably simple but The dealer will look to make a federal case from it based on my experiences from the past .
Any input valuable input would be greatly appreciated .
Thanks Jimmy
Thanks Jimmy
yes it needs a new lock mechanism and no programming is necessary but its a bitch to replace. its tough to remove and to get out of the door. you need a lock actuator. you need to remove the outter door handle and possibly the window rail inside the door.
Okay Great , Thats what I was looking for . It seems replacing some components requires two types of computer programming like the dual heating control . A valet attendant damaged the LCD and I went to replace the unit myself and was told that additional synchronization with an ecu was required and the days of the "do it yourself" are over . Everything is programming .
I will get an estimate from the dealer hopefully it wont be too bad but I expect a nice kick in the *** .
At the moment its semi working so I can deal with it but I dislike thing when they dont work properly and when you leave them it just accumulates .
Thank you for your input , it is greatly appreciated . I will ll post the outcome .
Jimmy
Jimmy
Repaired
I looked it up on the Repair manual CD and found that it looked like some job . I took a chance bringing it to the dealer .
I was told that they have to replace the actuator first in order to identify a second possibility .
So the part Mercedes of Huntington charged me 170 dollars where Silver star would have sold me the part for 130 dollars . The labor was 2.8 hrs .
Long story short , They replaced the actuator . I only needed the original Idea so It cost me just shy of 600 dollars for the repair .
On a another positive note , I had the Privilege of using a Loaner car an Ml for about 4 days at my convenience . Had I used a Mechanic friend , It probably would have saved maybe 100 dollars , I would have needed a ride home from the auto garage and would have ben without a vehicle . So it may have been a nice chunk of change but the loaner balances it out .
Thank you for your original thought .
Jimmy
Jimmy
legenesepimp
11-02-2005 05:04 PM
