Speedometer Sensor
Speedometer Sensor
Hi everybody
I have a SLK 200 / 2001 and the lights of Abs/Esp and Check Engine turned on few days ago. At the service they red the faults from the computer and they said to me that the rear left speedometer sensor has problem and needs replace. Does anybody knows where is the position of this sensor? Are they 2 sensors (left&right)? Is it posible the problem to be only on the cable-connector of the sensor?
Thank you.
badi
Thank you.
badi
RE: Speedometer Sensor
Thanks Sleepwalker! Great pic!
I will check the sensor but is it posible, driving the car untill i fix it, to make bigger damage to engine or to electronic firing? cause the check engine light is on and i feel the acceleration of the car (but only when i am in low rpm) not very smooth. Thanks again!
Best Regards,
badi
Best Regards,
badi
Hello everybody..I'm an italian engineer, I am looking for some data regarding my SLK R171 200K. I cant find them online, i searched everywhere...I'm looking for:
gear rates (for all the 6 gears)
final trasmission rate (differential rate)
Can anybody help me??? Please!!!!
Laidbackkat1
10-31-2009 11:15 AM
