SLK means ****ty Lousy Krap
can you do the same thing the guy in Wuhan, China did?
let the water buffalo or any animal (including your service adsor) to pull the car on the middle of the park.
call the press people, and start smashing the windshield and other replaceable parts with a scary looking sledge hammer!
hi this might help but there is a problem with the O2 sensor wire rubbing on the drive shaft and shorts out a circuit in the engine control unit (please chech and if it is rubbing then replace the O2 sensor and the fuel pump relay) also check the ckp they go faulty to when the get hot they break down and then when you leave it for about 30 mins it will start again i hope this has helped
450SLC_Spokane
May 20, 2006 07:35 AM
