remote will not lock or unlock doors
everything else seems to work but the remote will not lock or unlock doors..the lights flash but that is all when I press the remote. I checked the fuse under the hood and it's OK. Could a week battery in the remote cause this? 2000 SLK
The fact that the lights do flash, indicates the remote is working, and being received. Also, the fact that the dash switch does not unlock the doors, makes me believe the PSE is the problem. It may not be creating the pressure needed to activate the lock/unlock action. Also could be in the electronics in the PSE. Take a good look at the unit and see if you can spot any obvious problems.
The PSE is usually fouled by water damage. I wrote-up resolution of my water and PSE problems in this post:
http://forums.mbworld.org/forums/sho...d.php?t=260347
HTH
Thom
HTH
Thom
PSE's have been repaired. However, it's part luck, and part skill. Better line another one up. There's no info out there for trouble shooting. I just used basic electronic trouble shooting methods, and got lucky one time.
jason7570
Jan 4, 2013 01:47 AM
Srazz01
Jun 13, 2011 09:44 PM
diyw124
Oct 12, 2009 09:18 PM
