Help Trouble shooting P0440 code
Old Jan 22, 2006 | 06:30 PM
greasemonkey's Avatar
Default Help Trouble shooting P0440 code
Has anyone diagnosed this code? have not found a lot of info on it. I know it is an emissions code but nothing deeper. Thanks Skip
Old Jan 29, 2006 | 03:42 AM
vytamenc's Avatar
Default RE: Help Trouble shooting P0440 code
po440 is a leak in your evap purge system check your gas cap first. then perform a leak test of the evap purge system should not leak down more than 5 mb over 1 min. if it is indead leaking then install a smoke machine to the system activate the charcole cylinder shutoff valve and start pumping smoke into the system where ever the smoke comes out is your purge system leak.
pseverin
Oct 24, 2012 06:08 PM
pseverin
Oct 20, 2012 08:10 AM
tomw774
Aug 22, 2010 11:35 AM
ED500
May 23, 2009 04:03 PM
Brandon Sinclair
May 16, 2004 03:38 PM
