99 slk window adjust
Hey i have a 99 slk and recently had my driver side under the small window and had it painted since then the driver door window makes a whistle sound and i discovered that the plug under the door is missing ..anyone have any ideas how to adjust the window..
RE: 99 slk window adjust
There is a screw under that plug used to adjust the window. It adjusts the fit closer or further out from the body.
Thanx for the tip
Mine whistles to.
Can you adjust it without removing the interior door trim? |
I found out after paying 70 bucks at mb that there's a plug under the door that has a bolt that can move it in and out...if this does not help you have to change the rubber seals very expensive theres 4 one is 40 bucks the next is 50 thers one for a 100 then th most important one is 400 bucks plus 2 hrs labour at mb...this is for oneside only.
