trunk release
trunk release
I have a 1999 SL500 and recently I've been having a problem with the trunk release. I try to release it with the remote and also with the inside button and it doesn't open. I can hear a noise, that sounds like a motor when I try either way. I have to use the key to open it. Sometimes it works fine. Has anybody had this problem and how did you solve lt. Thanks
RE: trunk release
Sorry to say that this problem has been reported on other forums with no real answer. Mine seems to be worse if it is very hot outside. I just replaced the mechanism that lifts the trunk up. However, I don't think that helped.
RE: trunk release
Hello gentlemen. I'd like to find a way to get into a trunk that will not open via remote OR key. From my searching, it appears that the the electric/vacuum lock mechanism is fine, but the actuator is completely inoperative. This unit is a 96 SL500. Is there any access to the trunk if I remove the hardtop and raise the rag?
Your assistance is greatly appreciated.
jason7570
01-04-2013 01:47 AM
dee2000
07-21-2011 07:43 PM
