SL500 Rought idle/No power suddenly
Well, what I ended up doing was using a punch in the center of the pin to start a pilot hole for a small drill bit. Then, I carefully tapped in a bold extractor bit into that hole, and slowly rotated it to break it loose with a vise-grip. It was pretty effective, but I just found out that the seal is the only thing that holds that thing in place, and I could have apparently just pulled the entire center piece out if I wanted to. Now I just need to find a dowel that I can use to replace the pin and I should be good to go. I found all the parts I needed for about $200 on autohausaz, so I am pretty excited about that, too. Hopefully we will have this thing running by the end of the day!
nice goin'. necessity is the mother of invention. you'll be able to save yourself all kinds of money in the future. think about subscribing to alldata.com. doesn't cover everything, but helps.
