SL500 2003 fusebox diagram cant open glove compartment
Old Jan 26, 2007 | 07:19 AM
Tom_Tom's Avatar
Default SL500 2003 fusebox diagram cant open glove compartment
Hi, Please can anyone tell me where i can find a sl500 fusebox diagram, The problem i have is that i cannot get into the glove compartment, but after looking in the fuse box i can see that i have a fuse missing and thought that this may be the cause of my problem. There are 5amp fuses either side of it but i dont want to go shoving fuses in until its the right one. Any help will be greatly appreicated.
Tom
Old Jan 27, 2007 | 05:30 PM
bobterry99's Avatar
Default RE: SL500 2003 fusebox diagram cant open glove compartment
It is common for the glovebox to get stuck. If you do a search on the various forums, you may find some information. I posted on this website that I had the instructions to fix this, but I accidentally deleted them. I had obtained them from one of the technical service bulletins found at www.startekinfo.com.
Old Mar 8, 2007 | 09:29 PM
chassis221's Avatar
you can pop off the side panel on the passenger side of the dash, beside the glove box. use a long thin screw driver and if you look in there you can see the cable for the glove box latch, usually push cable toward driver side and that will pop open door.
jjjjf0
Jun 7, 2009 11:16 AM
gc
Jan 10, 2009 07:26 AM
C280 SPORT
May 7, 2008 09:05 PM
mbespaƱa
Nov 19, 2007 08:13 PM
Brigadir
Nov 22, 2004 05:08 AM
