SL500 1998 Hard top manual operation
Old Jan 7, 2011 | 03:36 AM
Frank Muscat's Avatar
Default SL500 1998 Hard top manual operation
Hi All,
Anyone know how to install and remove the hard top manually?
Old Jan 8, 2011 | 08:17 AM
SunGuy62's Avatar
Frank,
The procedure for top on/off is detailed in the Owners Manual. If you don't have one, this link will take you to another forum where you can download a copy for your model year. http://www.benzworld.org/forums/r129...ml#post2391320
You'll also need the so-called 'special tool' that's in the toolkit originally supplied with the car. Look for the 'thing' that you don't recognize (5mm hex on one end, open end wrench on the other about 10" long) If you don't have it, they are available at the Dealer for around $15.
Old Jan 8, 2011 | 11:36 AM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
Default Releasing the hardtop
Maybe I'm mis reading your question; but, the hardtop is manual. It is very simple. Unplug the defrost wire near rear edge of drivers seat back. Open both doors. Turn key on and within 10 seconds, push the top release button on the console toward the REAR. The top should release and pop up.
Find a tall enough assistant to help you lift and carry off the top to the rear of the car. They don't need to be super strong, just tall enough to lift the top and not drag across the trunk. If the system doesn't operate, you'll need to follow Bob's instructions.
DesignoSLK
Mar 20, 2009 07:17 PM
wcassel
Aug 5, 2008 01:27 AM
mmbenz500
Aug 25, 2006 03:30 AM
jckawan
Jul 14, 2005 08:22 PM
rodster13
Aug 27, 2004 11:01 PM
