R107 280sl
Old Jul 28, 2012 | 09:51 PM
victorccb's Avatar
Angry R107 280sl
I have a idling problem with this car. Appreciate if someone can give some advice.
The car starts easily and idles at 800 RPM. I think it should idle higher than 1000 RPM until the engine warms up when it will run at idle setting. It drives well without any problem until I stop the car and restarted it later. The engine cranks and reached 800 RPM and quickly dropped down to 500 RPM and alooks like it is going to die To prevent the engine from dying I press the accelerator and increase the RPM to about 1200. While maintaining this speed I could hear the engine is struggling to keep this RPM. When I realease the pedal the RPM fell to 500 and spiral down further until it dies.
I have so far changed the following parts -
Ignition Distributor
Spark plugs (old spark plugs in clean condition)
Warm Up Regulator
Decel Air Circulating Valve
Fuel Accumulator
Fuel Filter
Combustion Chamber clean with additive
Appreciate if someone can advice what is causing this problem.
Victorccb
Old Aug 12, 2012 | 02:29 PM
brookings's Avatar
how long does it faulter after you restart it? does it act like it's flooded then clears up after a few seconds? injectors can cause that.
Old Aug 19, 2012 | 01:41 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
Sounds like you have checked many things, but I see no mention of the air cleaner. It may be dirty or otherwise obstructed. This would explain many of the problems. I can't tell from your email whether it restarts easily. Might look and listen for vacuum leaks or
fuel filter in need of replacement. I usually check the DIY stuff first.
Old Sep 29, 2012 | 06:04 AM
rdrunner1974's Avatar
Default Idle
Have you checked all vacuum lines? With it at steady idle, spray some carb cleaner around the vac lines. If the idle increases, you have a vac leak.
Also could be a faulty idle control.
280sl_oz
Mar 11, 2011 10:12 PM
DJC996
Feb 15, 2011 11:23 PM
crusader47
Aug 17, 2009 07:19 PM
Global Car P
Jul 4, 2008 03:28 AM
jimwalker23
Jan 17, 2006 05:46 PM
