oil pressure light
I noticed on a test drive of my 300sl the oil light only comes on when you accelerate hard and goes off when ease off and drive normal, there is good oil level pressure what can it be ? Is it a electrical issue ? Also when indicating the seat belt light come on for a few seconds odd one that.The car has been standing for a while,every thing else works perfect
There should be a oil pressure gauge and an oil level light. Is it the oil level light that's on? does it also come on around turns? the oil level sensor is inside the oil pan on drivers side. pull wire, with an ohm meter test sensor pin to ground. if over 0.10 ohms replace. doubtful, maybe a bad wire to instrument cluster. the puzzle, why does your seat-belt light come on? you don't have any signs of mice? I know the first thing you've done is check your oil level?
oil pressure light
Originally Posted by brookings
(Post 168062)
I'll have to check the oil sensor and if it is the sensor is it costly to change ? Electrical problems with the seatbelt light is odd maybe shorting or damp has been standing a while. Other than that I'll have to put some cheese down and catch the mouse and have a chat with him. |
