New guy here
Just joined this site . I have several MB in my possession and I need some clarification. I own a 1993 300sl with 87k miles on it and as normal the cloth top wont come down or go up.
I also have a 1999 slk 230 and I had the same issues with the top on it. I just need to know if the electrics and hydraulics are the same for both cars . I need to troubleshoot the 93 and need a point of reference to start from. I don't have an owners manual so I need some guidance . Thanks My name is Earl I am in Hickory NC 1 hour north of Charlotte . Thanks |
Originally Posted by red93
(Post 165392)
new guy
What do you mean by normalized ? Found it thanks Ill try it tomorrow
[QUOTE=red93;165394]What do you mean by normalized ? Found it thanks Ill try it tomorrow[/QUOTEJust try unplugging the control unit. and plugging it back in. then try the roof.
normalized means, the auto/ 1 touch down feature. |
where is control unit ? Sorry to be so dumb. I don't know a lot about this vehicle , So, most of it is new to me. This is my first soft top MB.
the controller is in the bottom of the storage compartment just behind the passenger seat under a plastic cover. should see a red button on the compartment lid to open. the connectors on the controller have a slide type pin to lock the connectors in place. to synchronize top, with the windows up, hold down on the two window switches at the same time in the up position for about 8 seconds. check the large strap type fuse in the trunk next to the right trunk hinge, look under the screws too. check pump oil reservoir under the spare tire. as for the slk's top not working, the most likely culprits would be the two left and right locked limit switches above the visors. check pump reservoir in the right trunk well panel. the two systems are like night and day different. the sl is far more complicated
I had a heck of a time repairing the SLK top. Front latch cylinder was leaking then had wiring pinched with a metal clip used to hold wiring in place causing a short. But finally go it working and all is fine. I thought maybe the 300 cloth top would be different . Oh well, that's the price you pay I guess. Just needed some place to start on this one. I have ordered an owners manual for it . I'll let you all know what I find . Thanks
