Mercedes 300SL
Mercedes 300SL
Hello guys...my cousin has a problem in his 1993 300SL 24V ...when he tries to open the softtop electronicly...the driver side sunshade area starts leaking oil from there ...every mechanic asks for much cash just to CHECK...i want to know whats the problem if its a common one...and if it is easy to fix without the need of a mechanic...HELP plz and thank you
Cylinder leaking. The other side will start leaking soon. Contact Dennis below. He will rebuild your cylinders for less tha $50USD each. I believe he'll also supply instructions on how to change them.
Contact:
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 544-4521
mercedescylinders@sbcglobal.net
Cheap, fast, and no more leaks. ps - use only the correct Mercedes fluid!
Contact:
Dennis Ficken
16285 S. Chester
Olathe, Ks 66062
(913) 544-4521
Kitlander
11-29-2021 11:51 AM
skrooz321
10-03-2005 02:41 PM
