Mass Airflow Sensor
Old May 4, 2005 | 05:57 AM
R129's Avatar
Default Mass Airflow Sensor
What are the symptoms of a failing MAS on a 94 R129? Is this a common fault?
Old May 4, 2005 | 02:45 PM
sleepwalker's Avatar
Default RE: Mass Airflow Sensor
slight backfire from air cleaner area during acceleration. sluggish acceleration.
Old May 4, 2005 | 06:42 PM
R129's Avatar
Thanks Al. Apart from these symptoms, is it possible to have a rough or erratic idle and slight hesitation on acceleration? If the MAS fails completely, will it stall the engine and leave me on the side of the road?
Old May 4, 2005 | 10:41 PM
if it's really bad, erratic idle is possible.
by disconnecting it, the idle will be regular but no power. the engine will run on a fixed ratio.
it won't stall on the roadside. it will go to "limp home mode". if your engine control unit is okay, it will get the value from the throttle position potentiometer.
Old Jul 9, 2006 | 10:28 AM
schweij's Avatar
Would a bad MAS also cause the car not to start when it is hot? my 95 sl500 starts great when cold, but after only 10 minutes it has a hard time accelerating from a stop and will stall. Also, if it cuts off, it will not start. I have to wait an hour or more for it to cool down until it will turn over again. Obviously this is a big problem in the summer because the car get hotter and stays hot longer.
Old Jul 9, 2006 | 10:53 AM
yours is crankshaft position sensor problem.
car can still start even if the airmass sensor is faulty. there is substitute value for it to keep the engine in limp home mode. but engine will run rough and with very limited acceleration.
ddmracing05
Nov 25, 2007 08:19 PM
KHOLLA
May 23, 2007 07:33 PM
bigmack
Feb 6, 2007 04:49 AM
steelergrl
Oct 30, 2006 12:30 PM
97e320auto
Apr 22, 2006 09:00 PM
