the kombiinstrument
I have a problem with one of my friends SL car. When he start the car then it should be a check for 5 seconds on the instrument board ( the kombiinstrument) I mean that the light will light for 5 seconds, cause it is checking. But his SL does not do it....and I have checked the settings for it and the ARMDA setting but all seams to be right.....what can it be?
thank you
thank you
ARMDA is the modul which is taking care of the Airbag system......
and I have check it.....and about the wires I do not think so cause I know and I have check it.....and the ece I will but I do not think so cause I have a program so I can read from the car and see the thinks I have to analyze
and the lamp hehehe no no that is not the problem I also think
but thank you guys !!
since airbag is the first safety item that could save your friend's life, it is better to scan it for any fault code.
seems the airbag control module got an interrupted power supply. if the scanning tools can recognize it, then maybe some wiring problem, if cannot, then you know what it is.
