it's bad enough the r230 doesn't have a dipstick
it doesn't have a drain plug either. oil has to be sucked out of the dipstick tube that doesn't come with a dipstick. what in the world are they thinking. I just ask why not! I ended up buying a dipstick and now a pump. the turds. I suppose it will be nice not having to jack-up the car and crawling under the car to change the oil. I'm just old school though.
I agree, it is annoying. I think their thought was that people would just be bringing them to the dealer for service, so why bother..
as much as I was disappointed in not having a oil drain plug, I got my mityvac 7201 pump and did my first top side oil change. It's a little slow but by the time you get the filter ready to go back in it will be close to the time to put oil back in. so what do I think about not having a drain plug now? first time I could do a complete oil change in my bathrobe without getting dirty. I put another 1/2 quart in after the initial extraction and pumped that out to help clean more of the old oil out. the pump also reverses direction too, so you can pump the old oil into your container of choice.
fyi, there is an oil drain plug on the back side of the oil pan. found it while trying to install motor mounts
Light Sensor
My C240 showing me an ERROR (Light Sensor Visit Workshop) I then realised that my wiper does not work when set on Auto while the lights remained ON all ways |
Where did you buy a R230 transmission dip stick?
I see from the thread above that you did buy a transmission dip stick for the R230. Where did you get it?
as far as I know you can't get a transmission dipstick, oil only available. you have to check level for transmission underneath with the standpipe attached inside the pan. I really don't like Mercedes thinking on this. you have to pump fluid into the transmission from the drain plug, overfill, disconnect and wait until fluid slows down draining, then put plug in. the height of the inside standpipe is the proper level. car must be level.
There is a transmission dipstick tool - not an actual dipstick that you can leave in.
https://www.pelicanparts.com/More_In...9-15-21-00-M36 |
I got one of these for my r170 slk 722.6 transmission. can't use this on my r230, no tube to put it in. the only tube at the back of the engine is for oil.
Originally Posted by brookings
(Post 175792)
