Hardtop and softtop question
Old May 12, 2021 | 05:04 PM
Nancy Moore's Avatar
Default Hardtop and softtop question
The button for the hard and soft tops continuously flashes. Would like to know how to retrieve the code in order to fix this problem. Thank you.
Old May 14, 2021 | 01:09 AM
brookings's Avatar
Angry
what year? does it flash without pushing or pulling. If not, I just had the same issue. Luckily I had an extra controller. for me that was the issue. there is a way of checking all the switches from the long wire connector on the controller but I think it's the controller, might check the bottom fuse in trunk.
Old May 18, 2021 | 01:58 PM
Thank you, it's a 1990 and yes the switch flashes without touching it. Where is the controler?
Old May 19, 2021 | 11:34 AM
brookings's Avatar
the controller is in the compartment behind the passenger seat. might unplug and reconnect connectors attached to controller to see if there is a bad connection. the end connectors have slide plastic locks. the flash code can brought up through the block at the back of engine engine compartment by shorting 10 and ground for a few seconds. normally the codes would flash through the top button, counting the flashes would indicate the code but with the with button already flashing that would be a problem.
kevlex4
Nov 18, 2015 03:25 PM
kbest
Dec 15, 2009 01:00 PM
Mr.47
Nov 19, 2007 08:04 AM
JEFF D
Sep 1, 2006 12:27 AM
blubenz
Dec 30, 2005 01:03 AM
