Driver's Seat won't release and fold forward
Old 08-21-2008 | 02:36 PM
guitarmannwv's Avatar
Default Driver's Seat won't release and fold forward
I just got my new baby. The one I've always wanted. A 1990 300SL with only 50,000 miles. The only problem so far that I can find besides a small hole in the exhaust (Apparently common on older Mercedes because I've had to repair the same problem on 3 of my others that I've had), is the driver's side seat won't release to fold forward. The passenger side works fine. The driver's seat will release when the seat back is adjusted rather far forward. Thanks for any input
Old 08-30-2008 | 02:32 PM
brookings's Avatar
Default RE: Driver's Seat won't release and fold forward
take the two long screws out from under the front of the cushion and lift up firmly on the front of the cushion and remove. Move the seat forward. Remove the two torque screwson the bottomof theback panel of the seat. pull down on the back cushion and remove. check operation of the cable. If it's not broken there is an adjustment to tighten the cable on the bottom side of the seat release handle.
Old 09-05-2008 | 04:07 PM
That fixed the problem. Just needed a cable adjustment. Had a time getting the torque screws back in the back cushion, but it works none the less.
Lawbrum319
06-28-2013 09:53 PM
wkhall
05-25-2011 05:39 PM
weharrison
09-01-2010 01:50 AM
Heisler44
06-25-2010 10:10 PM
NYC.TCHEN
12-09-2005 12:08 PM
