battery charger
does anyone have recomendations for the use of a trickle
or float charger on SL..the owners manual discourages it.
i dont drive mine much in winter and the trunk battery
gets low enough for the battery off line alert to come on.
help..
glen
help..
glen
I just pull the ground wire on the battery when I let her set for more than a few days. With those cars pulling power all the time thebatteries today don't stand up to getting drained and charged all the time. So far I've had no problems at all by pulling the ground. The battery is always ready to go when I want to take her for a spin. I use a trickle charger, but I disconnect the cables.
you have to reset your clock, push memory for your seats, mirrors and steering wheel, no biggie if they are still in the same position as before. reset your radio. Small sacrifice to save your battery. Is there a battery somewhere other than the trunk that I'm not aware of?
thanks all...
im using a low current vector/black and decker charger that float charges at 12.7-3.2 volts..and when balanced it is only putting 10- to 50 ma to maintiain memory devices.
and so far ive only used it on the appliance battery in the trunk....and yes the 2003 sl 500 has a start batttery up front and a 70 ah unit in the trunk that runs only the "appliances"
...interesting to note...the mercedes battery seems to be made by johnson controls.
tnx
glen
tnx
glen
well that's something I didn't know about the 230 having a second battery. seems like a good feature over my old 129 with the one batteryfor all functions. BTW those 230s are really gorgeous.
carid
12-04-2014 02:44 AM
kikimouse
02-14-2006 09:40 PM
sunil_2.0Fiesta
01-12-2006 08:17 AM
