560SL Running rough - Fix before putting in storage or wait until spring?
My 87 560SL has been running rough - started misfiring this summer. I put it in storage each fall until the spring thaw in Ohio. Typically when I put it in storage I pull the battery and put fuel stabilizer in it. For the last 7 years this has been fine and in the spring it fires right up.
My question is should I have the problem diagnosed/repaired now and then put it in storage or does it matter if I just wait until the spring and then have it looked at then? Any suggestions? |
why wait until later for what you can frustrated over now...had similiar problem...replaced fuel filter and while there replaced fuel pump that was about 6 years old. no more rough idle and also ran "blaster" injector cleaner through a tank of gas..good luck!!!
