380sl stalls when warmed up
Old May 20, 2025 | 01:14 PM
buyer's Avatar
Default 380sl stalls when warmed up
My 1985 380sl starts up easily, idles perfectly, acceleration is very responsive until the car engine has warmed up. Once warmed up the car idle drops so low that the car stalls.
If I disconnect the idle control unit the car does not do this. It will continue to idle - allbeit a little high - after the engine warms up.
I've tested the voltage to the ICU and it consistently is 12v+ even after warm up. I have read that it should be 4-6volts once warmed up.
I have been working on this Mercedes for around 4 months as I have had time. I have replaced or rebuilt all of the fuel components from the tank to and including the injectors. The car sat for 14 years before I got.
Any suggestions on what to test or why the ICU is getting more voltage than it is supposed to after warm up? I replaced the Idle relay switch in the dash with no change in the issue.
Any suggestions will be greatly appreciated. I'm so close to taking it for a long drive up the coast.
MikeT
Nov 21, 2024 12:01 PM
woolym
Sep 28, 2010 07:27 PM
84 500SL Euro
Sep 23, 2008 11:00 AM
TBenedikt
Aug 6, 2005 02:08 AM
rosenlou
Jul 29, 2005 03:08 PM
