2003 SL 500 rear hyrdaulic leak
Old Jul 12, 2008 | 10:02 AM
mousegraves's Avatar
Default 2003 SL 500 rear hyrdaulic leak
My dealer tells me that that my rear struts have a slow leak and should be replaced....also that if rear was failing the front would soon follow so best to replace all 4 now. The charge is $4500 to replace struts, bearings, etc. How serious is this problem if I am getting no message from the internal diagnostic system? Can the fluid be topped off until problem worsens. FYI, car is only driven on weekends, less than 100 miles per week.
I just spent $1700 on the car to replace the shifting model, rear brake light and antennae housing.
Help!
Old Jul 15, 2008 | 03:56 PM
bobterry99's Avatar
Default RE: 2003 SL 500 rear hyrdaulic leak
ORIGINAL: mousegraves
I would suggest that a slow leak is not serious at all; and yes, the fluid can be topped-off. You can buy the fluid from a dealer, and the reservoir for the fluid is in the engine compartment and easily accessible.
orcldba8
Sep 11, 2013 11:06 AM
upsguy19
May 25, 2010 05:56 PM
PAULMJO
May 22, 2010 06:36 PM
500sel mark
May 6, 2010 03:20 PM
starwoodvo
Feb 14, 2008 06:09 PM
