1996 SL600 SURGING AT IDLE.
Old Mar 29, 2007 | 01:29 PM
Turborado's Avatar
Default 1996 SL600 SURGING AT IDLE.
It doesn't feel like a misfire, but it just kinda revs up then down at idle when it is warmed up. still runs smooth, but just "hunt" or "surges" instead of staying at a constant RPM.If anyone has any ideas or experienced this with theirSL600 let me know what it was in your case. Thanks.
Old Apr 7, 2007 | 06:19 PM
GrahamH's Avatar
Default RE: 1996 SL600 SURGING AT IDLE.
Had a very similar issue with my 500SL. Turned out one of the ignition coils was faulty. Could be the same problem for you?
Old Apr 8, 2007 | 02:49 PM
TheV12pwr's Avatar
Vacuum leak,check the rubber between the airflow and ETA's.
Crack wo'n be seen unles removed and inspected.
Good luck.
Old Apr 9, 2007 | 12:29 AM
97dmsrS420's Avatar
Put a scanner on it, you may get a P0507 code.
MWK220
Jun 2, 2010 09:25 PM
psychotuner
Jun 22, 2009 06:34 PM
Hot Rod Ron
Jun 13, 2009 04:25 PM
oregonboy
May 2, 2008 06:18 PM
Turborado
Apr 2, 2007 07:43 PM
