1994 sl500 ignition problem HELP 911
are the left and right ignition coils different?
my sl is only running off the drivers side distributor
if i pull the coil wire off the drivers side coil it dies
if i pull the coil wire off the passenger side it still runs
i replaced the passenger side coil with a used coil but the part number was from a drivers side coil. are the left and right coils different?
it still only runs on the drivers side dristributor
even iff i swap the coil wires from left to right it still only runs off the drivers side
i have already replaced the spark plugs distributor caps and rotors
and the ezl and the engine wiring harness
HEPL
HEPL
Myran
12-06-2018 03:17 PM
guero0898
13
07-20-2006 02:20 AM
mercedes sl500
06-28-2006 08:00 PM
