1993 600 SL one cylinder misfiring
Hello to all,
I have just recently purchased a 1993 600 SL in Switzerland, the car sat in a dealers showroom for almost two years before I bought it (I bought the car in
Italy and exported it to Switzerland, it seems not many people in Italy appreciate such a gas-guzzler...
) and it had several problems due to it being
inactive for such a long time; the brake pump and the suspension pumps had both started leaking due to the rubber components inside beeing cooked
by lack of use and I had to change both. The hydraulic suspension system was ridicously expensive to change (over 3000 €) but MB does not offer a
rebuild kit! I finally managed to change all these components (as well as the engine bay lining that was cooked by the engine heat) and my mechanic
tried it out... it worked very well for about five minutes [:@] and then the last cylinder on the right side of the motor started misfiring!
He then proceded to check the wiring harness which was badly damaged (it's cracked, probably by heat). He then proceeded to bypassing the
damaged part of the cabling but the problem still continued (works OK on cold, after 5 minutes goes back to 11 out of 12 Cyls).
He tried to invert the electronic boxes (left to right) but the problem reappeared again on the same identical cylinder (therefore it would not seem
to be related to the electronic side). Changing the injector does not change the symptoms (still the same problem). We are now in the process of
ordering a new cabling kit but given the tests that we performed it will probably not solve the issue (we tested by connecting directly the central
electronic box to the injector bypassing all the cabling and the problem still arises...).
Any suggestions on what it might be? I'm starting to get depressed (I've owned the car for two months now and used it only for one week!)
Thanks,
Robin
![Smile](https://mercedesforum.com/forum/images/smilies/smile.gif)
Thanks,
Robin
Thanks. I will forward to my mechanic and see if he can do it tomorrow (it is 20:00 here now...).
In the meantime I have received feedback from further testing:
My mechanic connected an LED to the injector (in parallel) to see what happened. This is the pattern:
Cold engine: Turn the engine on. Works on 12 Cyl. Led blinking each time Cyl n° 6 Right bank fires
Engine warmed up (roughly 5 min on idle): Motor working with 11 Cylinders. Led is constantly off (injector is closed)
will update if compression test on warm gives weird results...
Thanks,
Robin
Thanks,
Robin
Paid 25.000 US$ for it (has about 40K Km on it) but already spent over 8.000 US$ on repairs and spares, I also had it resprayed, since the owner never used it with the top down the paint was much lighter (sun exposure) on the outside of the car compared to where the hardtop was sitting (when open you could notice the shiny new paint where the top began and it looked horrible...).
So I could say that the total cost, up to today, was in the region of 33.000 US$ (but I still have to fix the Cylinder gremlin and pay for all the time it is taking my mech on this issue)...
One of the silliest bits I had to rebuy was the 600 SL badges... the previous owner had them removed!!! (all except the V12 ones on the side)
I also forgot to mention I had a new performance pack installed (extra power and torque) which cost me an extra 1000 € approximately (I can get more precise info later today once I get to the office)...
I was also thinking of getting new wheels (18 inch maybe) but I'm still in the process of evaluating the option,
any suggestions?
any suggestions?
As promised here are the performance pack details (European model):
Original HP 394 hp New HP 418 hpv
Original torque 570nm New Torque 661 nm
Speed: Old: 250 Kph New: 300 Kph
acc . 0-100 km/h Old: 6.1 sec New: 5.9 sec
I wonder if your mechanic effectively bypassed the original wiring to the injector, Robin. I would measure the resistance between the conductors which attach to the injector at the injector (key off). I'd measure with it cold and then hot. You should only measure very high resistance. If there is a short in the wiring due to bad insulation -- and I'll guess there is -- you will get a very low reading.
#9
I just spoke to him, he confirms that the cabling is very badly corroded and insulation is unsure. We ordered a new wiring harness which should arrive in a couple of days and will try that to see if it solves the problem. Connecting directly from the pin to the injector seemed to solve the problem earlier today but my mech says the wiring is in such a bad shape that working on it, as it is, is a waste of time since it might short circuit just by touching the cables. We agreed on waiting for the new cables to come in and try again. I'll keep you updated...
